· Registered
Hi all -
Does anyone know which speaker pins are for the two rear speakers on the connections for the Concert II head unit?
How would I tell?
Im going to be wiring a sub into the thing and I've got a speaker to RCA adaptor on order, but ive no idea which pin it is!
Cheers all
· Registered
The ones that arent on th ISO.
The green is the left rear speaker and purple is the right rear (the one with the black line are the negatives) (this is on my aftermarket HU, cant remmeber whether AUdi is the same).
EDIT: Just read it properly.
If you are keeping the standard headunit, you would have to just splice it off the standard speakers wires.
For the sub, the RCA adapter, it would go from the the speaker wires to the adapter in the RCA and then the Sub wires would connect to it.
But the quality will not eb as good if you had an aftermarket HU..
