Hi guys,
I have another noob question, this tiume about windows.
Was reading the manual and it says to get the windows sorted you need to hold the button until it close, release button, and then hold again for several seconds.
Did that, all my windows will close automatically when I pull the button all the way but the rear right, any ideas what can be the cause?
Got this sorted guys, apparently I wasn't programming this properly. Had another look at manual, and tried again and it works.
One problem less ;)
All left is the drivers door, atm it's slightly tilted down, as a result I have to slam the door a little bit harder than I would like to. You guys think this can be corrected with bracket manipulation?
Yeah, sounds like the door has dropped a bit. You should be able to readjust it. My 3dr Golf had to be done. Bodyshop charged me ?25 iirc.
