1 - 18 of 18 Posts
just to tell pepole that i have noticed for the first say 4 -5 minutes my car idles ok then starts to have a poor idle untill its warm
wondering what the probelm is
. dmf has been changed
cam timing 0.5
no fault codes
put air con on and it's ok
have read that my manifold could be clogged up due to high milage wondering what people think ?
if i had an small air leak by the egr syatem would i get an engine light fault ? injectors worn out ? fuel pump ? egr and flap has been cleaned out.
If you have VCDS go into the measuring blocks and check the engine water temp / sensor.
On the older generation 1.9's these were notorious for causing bad running.
Failing that, I'd suspect the EGR.
A dodgy coolant temp sensor or clogged EGR 9/10 times will not trigger a code.
Hence with the CTS go into the measuring block to observe what the sensor is telling the ECU. It might be telling fins to it!
ok will have to check i have vag com 704.1 whay block do i go to ?
i replaced cts with a german and swedish one wonder if to get a genuine one ?
Well if it's ok when the aircon is on then it has to be an idle sensor. And heat related. Could even be a dodgy ecu
Does the idle improve if you disconnect the engine temp sensor
I just meant some of the sensors that effect the idle. For diagnostics just when it's idling bad unplug that temp sensor and see if it makes a difference.
my car was running rough when i had an air eak between teh black pipe and IMF (intake manifold flap).
but because the ac helps, i doubt it is an air leak.
as per pm, temp sendor would be next on my cards as well as cleaning out the manifold as mine was clogggggeeedddd :D
yer checked they were putting out what they should be was told one was 0.01 out of tolerance but should be ok .
the ounly way i think to test um properly is to remove um and have um tested.
Discussion Starter · #14 ·
today is a good day....
have changed the fuel pump and all is good car idles fine and runs fine.
set idle to 830 is this correct ?
car would drive fine before but just had a poor idle .....
Yep thats the tandem pump. Pumps and regulates injectors on the fuel rail.
1 - 18 of 18 Posts
