I have just recently changed the oil cooler on my a4 and since then i have noticed the red oil light keeps coming on and off for a few seconds at a time especially just after start up once i have pulled away..any ideas..
If there is any air in the system that will happen. Ie If there isn't a good seal around the pipes. If there is, is the wiring damaged to the oil pressure sensor?
i would stop driving it with the oil light on.
get the sump pick up changed along with the filter asap.
have you remembered to add the volume of the oil cooler to the oil level ?
With all of above check my thread out about oil light had to change oil pick up pipe not to bad of a job if ur handy with a few tools
but i would check oil cooler is fitted correctly first
