Just to preface, this method has fixed my problem for now, im not sure for how long but its worth a shot!
T
he HVAC has 5 potentiometers / motors that control air flow and heat directions.
My Audi A4 has stopped blowing hot air on the left hand side of the car.
This is the lever / actuator. G220 Temperature flap left. These can be heard clicking when they get stuck in position.
Take the Unit apart by undoing the clips
This is what you'll find
Take out the motor
Next this arm
The potentiometer comes out next
Clean all the cogs thoroughly, as grease from the roller housings spreads and can cause the cogs to slick and seize.
Make sure action is smooth after clean, reassemble and install in the car.
Next connect to VCDS and realign potentiometers.
Job done and Hot air on both side.
For the record, the lever in question has been multiple times over the last couple of months with VCDS and would not play, it still would only blow cold, until this method was used.
Hope this helps.
Steven
T
Take out the motor
Next this arm
Hope this helps.
Steven
