I'm about to collect my new (well new for me it's an 07 plate) Audi A6 Avant 3.0 TDI SE Quattro today. I noted when i went out for the test drive the MMI didn't have amongst other things the nice graphic when reverse parking. Im guessing this means its in need of an MMI update. I know you can get the CDs from the dealer (part 4L0 998 961) for the latest version (5570). I understand it's basically a case of doing each CD in turn to apply the updates to all the components. Mine has MMI High with parking sensors, heated seats, dual climate, air suspension, DAB radio, AMi, 6 disk changer, Bluetooth.
Are there any gotchas for doing this myself? I was planning on just sitting there with the engine running and working through each disk.
I understand that post update some things 'disappear' such as the battery meter and require VCDS to re-enable,
So basically if anyone has done an A6/C6 MMI update and had advice, please share! Also if anyone has VCDS and is local to Leicester or nearby and can 'turn on' the missing items post MMI update that would be great too.
Always nervous applying these things!
thanks.
thanks.
