1 - 10 of 10 Posts
My mother has a limp mode issue with her TT, its an Sline TDI 09 reg. More and more often she is getting limp mode. I scanned her car and got the following fault codes, I will post the full logs under but heres the quick read version:
009571 - Turbocharger Boost Control Position Sensor Circuit
P2563 - 000 - Implausible Signal - MIL ON
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - Intermittent
I have cleared the codes a couple of times and quickly this one reappears
The rosstech wiki says to check the G581 and ohm test it but I dont know where or what it is specifically, internet said to check the N75 operation, when i did you could hear it clicking on and off when it should have.
I also did a Basic settings -> group 011 on another forum reccomendation but the numbers didnt follow what it said they should be, the boost mb stayed from about 959 up to about 979 on active and inactive, it said there should be like an 80 - 250 difference between them. The % in the 4th box also stayed within a very narrow band too around 15-25 low to 65 high, it said there should be 10% low and 90% high.
Here are the full fault scans and a full auto scan aswell.
Any help resolving this appreciated.
**********First Fault Scan
Tuesday,16,April,2013,17:51:24:39878
VCDS Version: Release 11.11.5
Address 01: Engine Labels: 03L-906-022-CBA.clb
Control Module Part Number: 03L 906 022 RC HW: 03L 906 022 BQ
Component and/or Version: R4 2,0L EDC 0000SG 3607
Software Coding: 0000172
Work Shop Code: WSC 01236 785 00200
VCID: 77FD31C6065682A0106
2 Faults Found:
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 2
Mileage: 109949 km
Time Indication: 0
Date: 2013.04.12
Time: 16:41:49
Freeze Frame:
RPM: 874 /min
Speed: 13.0 km/h
Voltage: 13.76 V
Lambda: 45.8 %
Lambda: -2.4 %
Bin. Bits: 00001110
Voltage: 2.584 V
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 110145 km
Time Indication: 0
Date: 2013.04.16
Time: 09:38:08
Freeze Frame:
RPM: 2093 /min
Speed: 106.0 km/h
Load: 61.2 %
Absolute Pres.: 1927.8 mbar
Absolute Pres.: 1479.0 mbar
Lambda: 98.6 %
Lambda: 50.5 %
Readiness: 1 1 0 0 0
**********Second Fault Scan after clearing and the fault returning.
Tuesday,16,April,2013,18:50:24:39878
1 Fault Found:
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 110188 km
Time Indication: 0
Date: 2013.04.16
Time: 18:43:09
Freeze Frame:
RPM: 1403 /min
Speed: 0.0 km/h
Voltage: 13.91 V
Lambda: 48.1 %
Lambda: -3.2 %
Bin. Bits: 00001110
Voltage: 2.508 V
Readiness: 0 0 0 0 1
********** Full Auto Scan (dont know why the CD changer fault is in there it never had one?)
Data version: 20121222
Tuesday,16,April,2013,18:46:05:39878
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 47 52 55 56 77
VIN: TRUZZZ8J391030783 Mileage: 110180km/68462miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 RC HW: 03L 906 022 BQ
Component: R4 2,0L EDC 0000SG 3607
Revision: 13H01--- Serial number: AUX7Z0I1FNI037
Coding: 0000172
Shop #: WSC 01236 785 00200
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 110188 km
Time Indication: 0
Date: 2013.04.16
Time: 18:43:09
Freeze Frame:
RPM: 1403 /min
Speed: 0.0 km/h
Voltage: 13.91 V
Lambda: 48.1 %
Lambda: -3.2 %
Bin. Bits: 00001110
Voltage: 2.508 V
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 614 517 A HW: 8J0 614 517 A
Component: ESP MK60E1 0020
Revision: 00H60001
Coding: 0083827
VCID: 2B55DDB68A9EF640A4E
No fault code found.
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 AP HW: 8J0 820 043 AP
Component: J255 Klima 1 Zone 0090
Revision: 00H08006 Serial number: 00000001125056
Coding: 1049620
VCID: 74E706CA1720E9B8354
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000009486420
Coding: 15020E8280141C804F1800001800000000084E075A250802800000000000
VCID: 489F823A3B283D58A9C
Subsystem 1 - Part No: 8J2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer AU354 H08 0070
Coding: 00064784
Shop #: WSC 01236
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -t Airbag 9.43 H02 0020
Revision: 93H02002 Serial number: 0036K003JHWE
Coding: 0011636
VCID: F9F9B7FEB04214D0E62
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004011
VCID: 41899F1E18120C106E2
Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 980 B HW: 8J0 920 980 B
Component: KOMBIINSTR. VDO H15 0360
Revision: D0H15007 Serial number: 2241I007002721
Coding: 0037428
Shop #: WSC 11111 111 11111
VCID: 306FCADAA3B8959891C
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K0922880C9
Coding: E9831F06100602004101
VCID: 377DF1C646D642A0D06
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
Shop #: WSC 00000 000 00000
VCID: 43859516020E1E007CE
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H15007 Serial number: AUX7Z0I1FNI037
Shop #: WSC 00694 210 103722
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8J8 959 801 E HW: 8J8 959 801 E
Component: Tuer-SG H03 0080
Coding: 0000637
VCID: 3F8D99E66EE67AE0186
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 8J0 909 144 C
Component: EPS_ZFLS Kl. 236 2302
Revision: 00H15000
Address 46: Central Conv. Labels: 8J0-959-433.lbl
Part No: 8J0 959 433 B
Component: KSG H11 0080
Coding: 1890300201182D298505489AD637
VCID: 3561FBCE5CDAB0B0C2A
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 8J0 951 177
Component: DWA-Sensor H03 0020
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 D HW: 8J0 035 223 D
Component: J525 Amp High H04 0160
Revision: PROD_01 Serial number: 00000000004643
Coding: 0236113
VCID: 25412B8EEC7AC03072A
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8J8 959 802 E HW: 8J8 959 802 E
Coding: 0000636
VCID: 408F9A1A1318051861C
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0050
Revision: 00000001 Serial number:
Coding: 0000024
VCID: E9D9E7BEC0E2A450162
Part No: 8E0 941 329 A
Component: AFS-Modul links H05 0030
Component: AFS-Modul rechtsH05 0030
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8J0 035 186 M HW: 8J0 035 186 M
Component: R Concert2+ H05 0270
Revision: 00H05000 Serial number: AUZ1Z3I9703309
Coding: 0730301
VCID: 3663FCC241DCBBA8CB0
1 Fault Found:
00857 - CD Changer Unit (R41)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 134
Reset counter: 123
Mileage: 96678 km
Time Indication: 0
Date: 2012.06.18
Time: 15:46:47
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005074117
Coding: 0001222
VCID: 46838C02313C2B285B0
End ---------------------------------------------------------------------
Ross tech is saying to check the actuator switch on the turbo.
Implausible signal means there is no connection to the sensor. So either the sensor is dead or there is a break in the wiring going to the sensor so it cant read it. The sensor should have a certain ohm reading at rest, and it is a way of checking the sensor.
There is a replacement sensor available with part number-- i only think its --- Repair Kit from VW 03L 198 716A
It mentions too checking the fuse so the sensor has the power to operate in the first place.
Hi sorry for the confusion about the ohm testing, yea I know to ohm check the sensor but don't know where abouts I would find the sensor to check it in the first place or what resistance I should expect to see if the sensor is good. Is there anywhere I can get this information, also about which fuse I should check?
I do have access to an Etka so will look the part number for the replacement up, it should indicate where to look for it too.
Im not sure on that model. id imagine all it can be are any electrical wiring going onto the turbo housing itself- on the actuator side. Try unclipping the plug, blowing on it :) and connecting it together again. Just to make sure that it has a good connection.
I know what it is now,
ScreenShot2013-04-16at214711_zpsd34602d5
I thought that was the N75 :rolleyes: But this is what was clicking in the output tests when the state was switching to on and off. This was while the car was parked and i was running the tests, if I cleared the faults it came right back and the car hadnt moved.
I'll have to see if I can find what resistance it should give.
In the mean time I will tell her to try un doing the plug, blowing and replacing, I know what you mean as I've had that happen with a coolant temp sensor before.
Thanks for the help.
My mother does accounts at a car garage and has a third party extended warranty on the car, I told her to get them to look at it and she told them about my logs and they have found out the actuator sensor itself is working fine, the diaphragm has gone! When told that the boost pressure barely moved in VCDS they isolated the vacuum and it wasnt holding any.
So its stil needs a new actuator, they are carrying out the work under the warranty and I've already given them the p/n you supplied for the repair kit.
Hopefully all will be well yes. Good job too as ive looked it up and supposedly replacing the actuator is a mammoth task :blink:
Hi - Just wondering, how did you get on with replacing the actuator? Did this resolve the issue? been receiving the same error on my 2010 2.0TDI golf.
Also been showing errors for 000175 - Actuator Module for turbocharger.
Any feedback would be greatly appreciated.
1 - 10 of 10 Posts
