1 - 20 of 20 Posts
hi wonder if any body could help have a3 sportback 55 plate 54k on clock when iam waiting at junction ect my car is very lumping like revs are up to high but there not feel my body shakeing abit had good expensive oil in it any ideas i live in ipswich is it worth putting it on a machine regards
heidi
It will have to be scanned with a fault coder to see whats exactly wrong. What engine has it got?
So its got lumpy idling?
It could be so many things, from spark plugs, Coilpacks, temperature sensor, MAF etc.
I just saw another post of yours saying its a 2.0tdi. Then i would suspect MAF, temperature sensor, injector wiring loom, anyone of the sensors,
It needs to be plugged in to a scanning machine/ fault code reader to see what the problem is really as theres no point replacing things just for the sake of it.
It doesn't always work but eBay have cheap hand held scanner which can read fault codes. Some independent Vw garages have the software too.
Id suspect any of the things that i mentioned mate up in an above post. Could be tons of things.
any luck with the lumping on your motor mate? im in same situation asyou but mine started when i got a charlie to fit my cambelt.
hi, well its been on a machine yestaday nothing so took it to someone who works with audi vw and he reckons its a injector on its was out s seen this before i belive me you dont wont to know how much as best to replace 4 of them so we thinking of tradeing it in for bmw 1 series
i did read if that happens after cambelt changes its the tension on cambelt is to tight? maybe but i havnt had one down so wasnt that on mine
You can just replace one. You can Buy a reconditioned one for around £100-150. Theres no need to replace all 4. The wiring loom that feeds the injector also is very common to be faulty and it makes a injector appear faulty. I wouldnt rush down the route of a new injector, and never 4 for that matter.
Why do so many "specialists" talk rubish. What fault codes did it have mate?
If you scan the car with a program called vcds or vagcom, it can tell you whether the timing is out and by how much it needs adjustment.
hi, we went and test drive a bmw 1 series not as nice as my audi but hubby really gave car a good thrashing which seen to sort lumping problem out he seems to think its down to me not working the turbo enough?? i drive it home and smoothe when at juntions ect how strange
Sometimes if the battery has been disconnected the car computer has to relearn new settings and driving styles. Hopefully thats done it for you!!!
1 - 20 of 20 Posts
