1 - 1 of 1 Posts
how do you test for low compression as injector 1 was out of tolerence -3.00 and the other inj were all above 0.1 have changed all injectors and wiring loom and still got the same fault.
for the first five minutes my car is ok then it starts to judder but only on idle . once warm it is ok.
timing is ok 0.5
flywheel and clutch have been changed.
if i turn tick over up its ok and if i put air cor on its ok...
1 - 1 of 1 Posts
