As above, my headlights keep blowing (dipped beam bulb and front indicators 99% of the time) it's not limited to one cluster either :-s , any ideas? dodgy earth?? Not really sure where to look :-/ ! However, when i went to swap the 'blown' indicator earlier i noticed the bulb hadnt blown but it wasnt working, put new bulb in and it worked, now it seems to have gone again a couple of hours later :-s! Anyone??
Sounds like its a poor connection. See if the connectors need cleaning and make sure you're plugging it in correctly.
Whens are they blowing,ie when you put lights on or indicators or igntion etc?
Id imagine its poor contacts. Can you wiggle the lamps around and the wiring too and see if it works?
Cheers for the replies guys, I think its contacts as all I have to do is remove the indicator holder take bulb out and reverse the process. Have given the contacts a good clean and slightly bent them out so they stand a little more proud, they were spotless though in terms of corrosion or any dirt/grease etc. Confusing!
Not sure when it seems to "blow", have not really noticed specifically
Tom
