1 - 8 of 8 Posts
changed all 4 injectors today due to high milage and injector 1 was out of tolerance but still have the same fault ...
could the wiring loom be faulty ? have changed injectors for some that had only done 25000.
What is the fault code tdiman? Most times it is the loom. Just from the vibrations of the engine.
no fault codes injector 1 was -2 . 2 3 4 were 0.70 on fuel injected. looking at other peoples faults may be the loom .... hope i get this car sorted soon...
is it easy to do the loom as may do this my self..
It is easy on the 1.9, not sure of the 2.0 though. Hope it goes well! I don't think loom is that cheap..
Expensive enough for what it is when you see it. Hope you get injector 1 back onboard!!
I reckon it might start working but the other 3 might decide they dont want to work as a team and go on strike
1 - 8 of 8 Posts
