hi all ive been offered a 1995 (s reg) a4 (uk spec) its been left on a farm for about 12 months and im trying to get it started and cleaned before i buy it.
i tried jumping starting the car and it started for about 2 mins and i then stopped it when i went to start it again the imobiliser light comes on and the car starts for 2 seconds then stops, ive looked on the net and tried various methods for fixing this ( i only have 1 key and its the original).
i think the imobiliser and/or key needs reprogramming and as the car isnt moted or taxed and i dont want to buy it till its running is there any other way i can reprogram the above with out going to a main dealer, can i use some software (vag etc) that i can do my self or could a mobile diagnostic guy do this.
thanks and any more info needed please just ask
ben
It could be a fault with immobiliser or just needs reprogramming. Try disconnecting the battery for 10mins And connect again and see if it clears the problem
would the battery cas an imobbiliser problem as im jumping the car to get it started.
the bat has been disconnected for about a day and the above is used
