Hi there Ive popped over from the golf site to ask about a scan i've just done on an A4 avant..
I'm thinking of buying it but was wondering how expensive it would be to sort the problems..
The scan is below'
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Mileage: 152810km/94951miles
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 LJ
Component: 1,9l R4 EDC G000SG 5781
Coding: 00002
Shop #: WSC 63251 AUZ6Z0C0428427
1 Fault Found:
17994 - Engine Mount Solenoid Valves (N144/N145): Short to Plus
P1586 - 35-10 - - - Intermittent
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 3429
Coding: 04255
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AA
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63251
1 Fault Found:
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00001
Shop #: WSC 63251
1 Fault Found:
01502 - Bulb for Rear Fog; Left (L46)
57-00 - Electric Circuit Failure
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
Shop #: WSC 63251 000 00000
2 Faults Found:
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
012 - Electrical Fault in Circuit - Intermittent
011 - Open Circuit - Intermittent
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 00042
Shop #: WSC 63251
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 M
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00401
Shop #: WSC 00847
WAUZZZ8E44A172529 AUZ6Z0C0428427
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0704
Coding: 00001
Shop #: WSC 00000
2 Faults Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
01462 - Anti-theft alarm ultra sonic Sensor (G209)
53-10 - Supply Voltage Too Low - Intermittent
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BC
Component: Komfortgerát T3B 1412
Coding: 07115
Shop #: WSC 63251
Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 0003
Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 0003
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0004
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0004
6 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01574 - Alarm triggered by Door Contact Switch; Right Rear
35-00 - -
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 L
Component: concert II GRO 0001
Coding: 01001
Shop #: WSC 63251
End ---------------------------------------------------------------------
thanks Moggie
Coding: 00002
1 Fault Found:
This is either the wiring or the Engine mount itself. These are about £200 from the dealer. Again dampens down engine movement but it doesnt prevent the use of the car.
Address 8 Auto HVAC
819: Could be a faulty sensor / low amount of refrigerant because of a failure or seepage over time. Could be expensive or as cheap as a £25 pressure switch.
Address 15: Airbags
2 Faults Found:
A faulty crash sensor no doubt, they often get damp because of their position or fail because of age. Itll be that or wiring. Again probably £70 odd for that sensor, i could be wrong with the price, but you have to remove the B pillar covers on the inside and change it. Takes about an hr or two to do it with all the trim back perfect - if youve done it before probably 45mins.
1 Fault Found:
Probably again a bad coolant temperature sensor, these are £20-25 odd and not the hardest of replacements, youll lose some coolant so youll have to have some to top up with. An hours job at most. 30mins if youve done it before, Incl topping up and checking levels etc.
Address 45: Inter. Monitor 2 Faults Found:
43-00 - Closed
The Alarm has come on since the last time the car was scanned for faults, and it was triggered by the G209 sensor. The sensor could be bad, or it could of had a low battery causing the supply to have low voltage, either way id delete it and it might never come back.
Same as these:
6 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
But double check the locking and unlocking and the alarm going off. Check the key buttons work and that the only way into the car is via sticking the key in the door. This will set off the alarm and can only be turned off by sticking the key in the ignition.
Ps alot of those codes are quite common and alot will have similar ones, the b6 is getting abit old now so will have a few problems, it gives a chance to walk away or barter down with the cost of repairs.
Thanks Stevee for the very comprehensive reply..
The car drives very well only other problem is a slight noise from a front wheel bearing..its showing just under 95k miles and has a few marks around it..
Think I will try and haggle the price down as my first impression is very good of the car..
I wil llet you know how it goes.
Thanks Moggie93
No problem mate, The front wheel bearings are £80 odd or more, and they bolt into the hub, its not like the old ones that press in and out [Y]
They all have bearings that way. It a way its easier and in a way its a pain in the ass.
The hub still has to come off so the old bearing can be pressed in and the new one can be pressed in square. They are such a snug fit.
Its tough to get the hubs off. They have 2 arms on the bottom and 2 on the top. And they are TOUGH to get off.
