1 - 15 of 15 Posts
Yeah they would mate but wouldnt bother with blue tint they look chavy n dont seem to be as bright as the white ones are like osram night breakers or the philips cystal ones
Good spot dave,think they would also do your foglamps if you have them,side lamp bulbs are a pain unless you do some wiring tricks or get some which dont bring on bulb out warning lights on the dash
He'll only have trouble with bulb out warning lights if he goes the LED route. "Normal" bulbs will be ok. [8-|]
Welcome to the forum, by the way!!
What are / were you wanting to change? The side lights or the dipped headlights?
Just for a bit of info to everone who wants to succesfully fit LED bulbs as their front side lights.
These are all you need to stop the bulb out warning
PUSH
We are using them in both the audi's and they work fine with these LED bulbs .
[quote user="j40hnw"]
PUSH
have you got these mate? if so any pics
Ive had no probs with these, they have a resistor built in. There is 2 leds per bulb. I think theyre ok. Will try for pics when i get on computer
[quote user="leach76"]
PUSH
Ditto Mr W, how do you plug these in and sit the bulb with the extra cabling + stuff to shove in place somehow?
C
PUSH
No pics as they are fitted inside the light behind the cover.
Or did you mean pics of them fitted and lit up?
1 - 15 of 15 Posts
