Giac remap at star performance.
7225 Views 10 Replies 6 Participants Last post by  b10cker
Well i thought this section could do with bit of banter seeing as theres a few s3's turning up now, anyhow ive just booked in at star performance for a giac hammer remap on my s3 which reportedly gives 320-330bhp.
Im not sure what other options i'll go for yet but i'll definately be getting the flashloader, the hammer map, and the standard map, i am also debating on getting the valet map which reduces boost to 0.4bar and bhp to 180, jim recons its worth about another 5 mpg on average and for £35 it would probaly pay for itself, for them times when going a bit fast just isnt possible.[6]
Anyhow i'll keep you posted and try and get a write up of the day and performance sorted out.
Paul
1 - 11 of 11 Posts
320-330Bhp! That's gonna be one hell of a car mate! [Y]
Liking the sound of the valet map, i could send Mrs Beddie to work all week with reasonable MPG and then go balls-out with the 320 at the weekend! [;)]
[quote user="b10cker"]
It'd be annoying if you were pottering around on the valet map and some spotty yoof pulls up alongside you at the lights in a ricer. It would be good if you could have a KITT style turbo boost button!
[quote user="wellsy"]
You can actually leave the flash loader connected at all times if you wish and switch while moving at the press of a button, apparently.
320 to 330 seems alot from a remap. I have read that a standard remap gives 305 to 315, think you would need exauhst from the turbo back to see 330.
but I could be wrong, ive got to wait 13 month or so b4 I can order my s3, but from the research ive done online 310 ish is what you can acive with just a remap.
[quote user="Anakin"]
[/quote] Aye i mentioned that to jim at star and he said that you cannot get realistic figurs from an s3 on the rollers because the engine and turbo generates that much heat that you cannot cool it enough. However on the road the 330 map apparantly has noticably more power than their 310 map, so as long as it feels good im happy[<:eek:)]
Can you do a 'butt dyno' with VAG COM on the 2.0T? That should be able to give an indication.
Mind you, the difference between 315 and 330 will hardly be noticable, surely? You'll probably only feel/see a difference top end which to be fair you're not going to be using a lot of on our policed roads!
I recently had a cat back Milltek system and green filter put on my MKIV 1.8t , Ive been driving round with the window down ever since. Im kinda upset I waited 6 years to do it. When I get my S3 in a year or so, new company car :) Im not going to wait that long again
Well here i am back from my weekend away and trip to star performance[<:eek:)]
We arrived up at star performance in kirkaldy just after lunch to find jim waiting for me and ready to get on with it, so after discussing what i was going to go for and pricing he got on with remaping my s3.
The first job involves checking which software my car was running to start off with and updating if required to the latest spec, mine was however up to date (version 7), he also told me that the car had not previously been accessed by anyone else, which i suppose is a good thing. My cars map is then sent off to giac in the us and within about 10 mins the modified map is returned and ready to install. We did however have some problems with my car taking the map which turned out to be my phone still being conected via bluetooth even tho i was in the waiting room at the time (apparantly bluetooth can interfere with it). so once that was sorted jim gave me a shout for the test run.
To start off with jim explained how the flashloader works and that it can be used whenever the ignition is turned on, even while driving. pressing read on the loader shows up what you have installed (in my case stock, pump, and valet) and you can then s elect whatever you want whenever you want.
I decided to first try the stock map to make sure the car drove as before and indeed it did, then while on the move i switched to the valet map to try that. This mode felt like the turbo had been pretty much turned off, so it felt pretty normal below 2000rpm but above that when the boost should be really kicking in there was nothing there just the same pull as below, i cant see me using this mode much but my run to and from work is usually 40 mph tops in stop start traffic so if it saves me fuel in that situation then i might, plus at least i can switch to 300 plus bhp whenever i want.
Anyhow on to the main event the pump map, again i switched on the move and could imediately feel a kick as the button was pressed as the car took on a more lively character. In traffic it didnt feel that much quicker but then a gap opened up off a roundabout and i floored it in 2nd and 3rd, bloody hell this shifts. So a large smile was now plastered on my face and the test run was complete so back we went to pay for the job seeing as i was happy with it.
After leaving star performance we were on a trip up to the scottish highlands via fort william and loch ness etc to give the car a good test, the roads up there are brilliant even tho theres more traffic than you expect, and luckily it was even dry all the 800 mile journey. Anyhow with all those miles covered with the car in remaped mode i can tell you that it makes the car pull really solid right through the rev range and there isnt much that can keep up now, the noise from the turbo has also increased a touch as you would expect and sounds a bit more purposefull when you have the radio turned off, i now fancy a forge induction kit to try and increase the sound a touch more tho. another bonus was that over the 800 mile trip the car managed to average 35mpg which certainly aint bad for a 300 plus bhp motor.
So all in all im more than happy with it and would defo recomend star performance and a giac remap to all s3 owners.
once back home i decided to mount the flashloader onto the mat with a picece of velcro and leave it connected at all times for easy switching like so....
Is there no where else you could house the loader? Looks as though it's highly likely to get damaged where it is at the moment. Could you not feed it into the armrest or ashtray? Would look a neater finish and it's away from prying eyes.
Unfortunately the cable isnt really long enough to run anywhere else and i wanted it so its quickly removable too. you cannot see it in the car with the doors shut plus it sits quite a bit lower than the sill, which you cant make out in the pics so it'll not get damaged either.
1 - 11 of 11 Posts
