gutted,was about to go for a spin in the A3 after driving it bk home from work and the bloody thing wont start,no sound from the fuel pump either but a relay clicking under the dash,anyone know of a quick fix or just buy a new pump?
thanks in advance
Take up the back seats so you can hear the fuel pump or not. The starter motor can make a clicking sound if the battery is low. Is the fuses all ok?
checked fuses and theres no sound coming from the fuel pump so could be a fault in tht ,its only done 70 thou,gonna do som diagnostics on it in the morningif i can get it off work
See what comes up with a scan then maybe. Before replacing the pump I'd take off the filter and see if when turning on the ignition and cranking if there is fuel coming out of the pipe...ie fuel pump is working or not. Then check if there's a 12v supply to the pump itself.
