On the A4 for example there are different part numbers for the normal mirrors and folding mirrors
IIRC
They are a direct fit...BUT
You will need the wire loom from the doors of the car they came from and possibly the control module from each door also.
Then your Central electrics control unit may not supoprt this feature as yours is an 05 so you might need this.
After you have fitted them you will still have the wing repeater in the front wings and that will look a bit pants if you have both.
Then as the wings are different where the headlight fits you will need 08-09 headlights/bonnet grille and front bumper
Oh and then all you need is for someone with VCD'S to tell the car that you have fitted all these parts
