1 - 2 of 2 Posts
I have done a scan of my car using VCDS and it has come back with 3 faults, one is a dud reversing sensor but the other 2 i would like some advice on and if there an easy fix.
First fault:
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000
VCID: 6DD1395D27FA78764F5-515C
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
41-10 - Blocked or No Voltage - Intermittent
Second Fault:
2 Faults Found:
000833 - Camshaft Position Sensor (G40)
P0341 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 3
Fault Frequency: 5
Reset counter: 255
Mileage: 120351 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 84 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 9.20 V
Bin. Bits: 00101000
Idle Stabilization: 0.0°KW
(no units): 3.0
012296 - Camshaft Position Sensor (G40)
P3008 - 000 - Signal Out of Range - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 120351 km
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
RPM: 252 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 9.50 V
Bin. Bits: 00101000
(no units): 35.0
Archie
The HVAC code is a error with the recirc motor. It may still work but its giving problems.
Depending on what engine you have the camshaft code could be a few things. It could be a dodgy sensor or it could be a slackening of a timing chain.
1 - 2 of 2 Posts
