Only had my A4 Avant 1.9 TDi 2 weeks and already I have this light on...plus both brake lights are not working at the rear....
The brake light problem is a cheap fix - £15 odd at the dealer for a brake light switch - id get it done sooner rather than later incase someone rear ends you.
The ESP could be anything with the ESP. It needs a scan really with vagcom. But in most instances its a ABS sensor that has gone faulty / poor connections / damaged.
[quote user="dundee_stokie"]
Had this problem with the esp light always on on my last mk5 1.6fsi golf. it was the traction control pump that had gone, there about £800 pound for a new one but i took it to a specialist and the sourced a second hand one and it cost me £350 fully fitted. hope this helps.
rob
ESP light could be a faulty bulb or anything - as said get it on vagcom. When i bought mine it had this and it turned out to be a dodgy bulb, was replaced under warranty from the dealer i bought it off luckily!
