after a bit of advice
basically a friend has lost a key for his car and so i was wondering is there a way to disable the spare key?
[quote user="k4na.x"]
You can reduce the key count in vagcom / vcds.
All you need to do is recode all the keys which are present now for the car, the lost key will then be wiped out.
It is pretty straight forward to do with vagcom and a little knowledge providing you have the SKC.
