1 - 13 of 13 Posts
Most of you will probably have seen this over on t'other side but for those of you that haven't, Asda are offering Demon Shine rinse aid at 2 2litre bottles for ?5. They're normally ?4.85 each so it's a good offer. Seems to be a popular budget product on detailing world.
I've picked up 4 bottles......should last me a while!
Neither. Seems to be a jack of all trades. You can use it as a quick detailer, clay lube and a drying aid. Basically, you can either mix it with water in a watering can, pour it on and it helps to sheet the water off, reducing water marks. Or you can spray it on to help repel the water and use a drying towel to wipe off. Its supposed to give a shine too.
That's pretty cool. Don't know how well it would apply Demon Shine though.
I just bought a small 1litre trigger sprayer and going to use that. The bottle says to mix it in a water can and apply like that. The open end of the watering can helps with sheeting the water off too. JimWD recommends using an open ended hose to sheet the water off the panels.
Ok, well in that case, it's exactly the same stuff and you've got yourself a bargain.
1 - 13 of 13 Posts
