Morning peeps,
I read some where that in the 2.0TDI you should change the oil regularly?
How regularly is regularly?
It will depend on how the car is set up for servicing, won't it? [:cool:]
Mine's on long life servicing so it's around 20k miles. If you're not on long life, I'd say it's 12k or 12 months. Nothing in the handbook? Oh, and if you change the oil yourself, make sure you use the correct oil!
As Dave said, 10k oil changes are norm good msintainance. You can go longer and it's ok, but oil isn't expensive considering what it does
