Hi I have an Audi A3 2.0 TDI, the ABS light and traction light come on simultaneously. Diagnostic test showed it was the rear left ABS sensor, got it changed, lights still on.
We then tested it with a multimeter, the rear drivers side wasn't giving any readings, so I changed that sensor but still no joy.
How can I resolve this?
Do you have vcds to read live data? You could try to read the data from each sensor to see what sensors the ecu can read. Remember that wiring or sensor problem will give the same fault codes
