1 - 11 of 11 Posts
Hey guys,
posted earlyer today reguarding a 04 plate 2.0 TDI but after reading up on the engine problems they have i've been put off a bit!
now looking into the 02 plate 1.9 130 diesels and just wanted to know peoples thoughts about the cars and any buying advice.
Good cars and good engines. Like all cars though check out the clutch, turbo on full belt to see if it boosts right and doesnt overboost- 3rd gear to the red line- 4th gear to 4,000 revs at full throttle. Itll test the clutch and turbo. Also check that all electronics work in the car- every gadget and also that the aircon works- alot dont.
But they are a good engine
how will i know if its overboosting and if it has any faults? i've never driven one before so wont know what to look out for.
you know its been a while since ive had my tt & starlet.. but if i rember right its you waste gate either stuck open or shut.
you try to give it the beans itll go then jump to fuel cut/limp mode so your turbo doesnt kill its self youd know if it over boosted as the car would practicaly die on you and only do like 12mph lol
Yes if it overboosts the power will be really reduced. Whatever car you chose dont be afraid to take it for a good test drive and really check it out including going over some bumpy roads to check the suspension for rattles and clatters.
coilies would be a tempting upgrade whats the going rate for a half decent set up on Audi's? i'm a ford lad really so this is all new scene for me
i'll give it a good test drive to check for the turbo and clutch.
Jom coilovers are popular amongst Golf/Bora lovers, similar with the A3. Pick 'em up for around £160-180.
Check the central locking works, locking/unlocking all doors and boot as expected - also check the map lights go on when a door is opened. Door module switch failure is very common in these and when pointed out, can gain you a bit more off the asking price. £10 fix from a scrapyard though.
Also check the wishbone bushes, they seem to eat them more than anything else.
Quick question.
I've been looking into remapping but i cant seem to find many 130's in my area only 100's.
if i remapped a 100 what figures would i see and would they be lower than what a 130 mapped would be? or is the 130 the same but with a less agressive remap?
thanks.
1 - 11 of 11 Posts
