thanks bud, still selling parts off the bora so they are going into the audi fund [
well the ebay decat guy decided after a month of saying he was going to get some more stock and send one across has refunded me, so after a frantic hunt came across FR&R tuning uk site, they had a 3" ATP decat pipe listed on the website, after a quick call they had one in stock for £200 so ordered it Tuesday morning and it arrived today.
haven't got any fitted pics as it was a real pain to get the old cat to down pipe bolts off, they were very corroded and almost inaccessable.
after fitting i took it round the block, it spools up much faster but seems a lot less torquey. and down on power towards the top end.
that said i discovered another issue, since i bought the car there was a faint rattle, it sounded top end so i cecked the fuel pump and changed the tappet, helped a little. the changed the cam chain and tensioner which made the engine quieter still. last week i thought i'd found the issue after youtubing 'tfsi rattle' the actuator arm rattles on the wastegate flap arm, i added a small amount of preload to the actuator to try and take up the play. it helped a little but was still there. the rattle sounded like a bearing in a tin and only on decelleration mainly between 2-3k revs. being that it was only on decelleration pointed toward the actuator again.
so when i had the cat off i had access to the wastegate flap and arm, what i discovered was a tad worrying. i could feel play in the wastegate flap - excuse pic
the centre rivet had loosened off and the flap had been vibrating causing the flap to break up, i shook the cat out and a couple of small bits of it were lodged inside.
all i could do at this point was put a weld on the arm to the flap to stop it vibrating, of course the turbo is dead and will not be performing anywhere near where it should with all the boost escaping but giving me extra incentive to get the k04 on. [Y]
