has anyone removed and replaced the door glass before ? after some pr**k damaged mine less than 24hrs after buying car .
sourced a new glass for 15 quid all i need to do now is replace it but ive heard you have to remove the door skin and not the interior door panel
done one of the windows today , i say one as the glass i got is a different tint so im swapping both . the audi is totally different than the vw for removing the glass
much easier as you remove the whole top of the door complete with the cables etc
40 mins later job done
amazed at the work in audi doors the vw ones are all steel , were as the audi ones are alloy , even the side impact bars are alloy to help keep weight down.
do the other side in the morning
Ive had my door off and not even noticed the types of metals! well done mate.
other side was even quicker to do , coded warning lights in as well , then did 1 touch unlock, alarm bleep , 1 touch auto windows ,steering sensitivty , illuminated needles mod
think i got a bit carried away .
also removed the seatbelt chime ,common sense tells you to use a seatbelt
