1 - 13 of 13 Posts
Hi
(I'm refugee over from ukmkiv's asking on behalf of a friend, so please go easy [:$]) She's got an A3 2.0 TDI. I'll try to explain using the descriptions she's given me (apologies) if you need more info, let me know and i'll find out
The enginge management light is on on the cluster. Apparently it's been scanned for faults and (her words) were it said something like throttle 'something' actuator.....
If that rings a bell or two - what's the process to fix the error?
What things can the engine management light relate to on an A3 tdi?
Would need the code number really. Exact same as VW mate with the codes.
There are a few throttle actuator fault codes. For example this is one of them
Fault 00282 Throttle postion actuator : implausable signal
Possible Symptoms
  • Idle Speed too high
  • Idle Speed Regulation in Limp Mode
  • Cruise Control System (CCS) not working- doesnt have cruise control
Possible Causes
  • Throttle Position Actuator (V60) jammed
  • Wiring/Connectors from/to Throttle Position Actuator (V60) faulty
Possible Solutions
  • Check Throttle Position Actuator (V60)
  • Check Cruise Control System (CCS)
Cheers Stevee, appreciate the quick reply
Will try to find out a bit more info (possibly the fault code) and get back on here
IMF, Bearings, dodgy turbos, leaky rads - all common probs.
Theres also the porous head issue - thankfully mines "only" needed bearings at 20k, a turbo at 60k and the IMF at 60k :)
Im not sure how much the IMF is at dealers but i think its £206 at GSF.
You should leave the IMF for sale sign beside your ad in your sig kaz.
[quote user="Stevee"]
Lol - Just got rid of it!
Thought Id keep it hanging about incase mine goes but then again - a new one cant go wrong, can it? lol
How did you get on with sorting the intake motor, did your engine mang light stay off? Its anoying to seee the light lt on, comon fault - expensive too. Why Audi? I would appreciate any help.
Tanx
jsut change it with the new revised part and alls ok.
renew all gaskets/seals and all will be good.
the new part no end in "M" as far as i know
1 - 13 of 13 Posts
